oric307
Feb 19, 2023Aspirant
NIGHTHAWK AC1900 DUAL-BAND WI-FI ROUTER
Hi: I would like to upgrade my NIGHTHAWK AC1900 DUAL-BAND WI-FI ROUTER. Can someone recommend a router. It must be compatible with EXTENDER EX7300, I have 3 of them. EXTENDER EX7300 must connect w...
Feb 20, 2023Guru - Experienced User
What AC1900 do you have? (ac1900 is a speed not a model)
Are you planning on upgrading the extenders?
Reason I ask is I usually recommend moving from extenders to a mesh (like orbi or mk nighthawk) system when you're needing more than 1 extender. And if you're looking at upgrading router's it might be worth upgrading the whole system.
Plus you'll only really see a speed benefit to the upgrade for the devices connected to the router.
- oric307Feb 20, 2023Aspirant
Hi: I have the NIGHTHAWK AC1900 DUAL-BAND WI-FI ROUTER
- microchip8Feb 20, 2023MasterDude,
AC1900 is a speed, NOT a model number. Look at the label on the router for model number. Most likely, you have an R7000.- oric307Feb 20, 2023Aspirant
R700 IT IS.
