RobS10
Feb 12, 2019Aspirant
Nighthawk AC1900 EX7000 or Orbi in lath and plaster house
I have a pretty typical scenero,a 1400 sq ft house, built in 1936, so lath and plaster walls throughout. Most of the living space is on 1 floor, but there is a room in the garage where we'd like to get WiFi, and possiby the back yard. The coax cable from my provider (Comcast) is in the front and back of the house with nothing in between. I also have CAT6 connecting the front and back. The main modem/router gateway is in the living room, and only coveres 1/2 the house due to the plaster walls (I get wifi 1/2 way down the block through the front window just fine). The devices connected are a two laptops, one printer, two TVs and three smart phones. We stream some movies, but not huge users of bandwidth.
I was origininally going to just add a simple Nighthawk router in the back but realized I would end up with another network to connect to and maintain. The idea of the Orbi system sounded great, but a little expensive for us. Would the Nighthawk Mesh extender accomplish this? Seems like the same setup as the Orbi but much cheaper. What is the drawback?
This is the Mesh extender I'm looking at...
https://smile.amazon.com/gp/product/B00R92CLD6/ref=ox_sc_saved_title_1?smid=ATVPDKIKX0DER&psc=1
- RobS10Aspirant
Anyone?
- apil1Apprentice
Orbi is a true peer-to-peer mesh where the satellites will daisy chain depending on what the strongest signal they can get is. Nighthawk is an add-on mesh component and is designed to prefer connecting directly to the router if it is within broadcast range even if another signal is stronger. If you are only adding a single extender this won't come into play. Nighthawk has more advanced user features than the Orbi. You may find a feature you want is not available on Orbi. If you want to create a One WiFi Name mesh network with a Nighthawk extender, make sure you are getting one that states mesh extender and not just range extender.
- RobS10Aspirant
Thanks Apil1,
Just looking for an affordable way to get the whole house on one network, from living room to back of house, including garage (about 60 ft.). Will the Mesh extender do that? Do either the Mesh extender of Orbi still allow the Comcast Gateway router to work where it's the closest (best signal), or do they "take over" and become the router instead, and if so, do they work well enough through plater walls? I want to connect either drvice in the back bedroom and want to be sure I will still get strong WiFi in the front of the house (since the Comcast router can't cover that entire area due to the plaster walls).
