RobS10
Feb 12, 2019Aspirant
Nighthawk AC1900 EX7000 or Orbi in lath and plaster house
I have a pretty typical scenero,a 1400 sq ft house, built in 1936, so lath and plaster walls throughout. Most of the living space is on 1 floor, but there is a room in the garage where we'd like to g...
RobS10
Mar 09, 2019Aspirant
Would you say the EX7000 Mesh Extender, connected to the main Comcast Gateway via CAT6 cable, would be the best bet to "cover" my existing network (both the 2.4GHz and 5 GHz frequencies) in the back part of the house that the main Gateway can't reach? I believe the Comcast Gateway helps the main DVR in the living room communicate with the smaller cable box in the back bedroom for recorded programs, and maybe the Orbi taking over would cause problems unless I bought the really expensive Orbi that has a modem and phone built in?
apil1
Mar 10, 2019Apprentice
That would put the extender into AP mode which would create a new wireless network. You have to connect the extener by WiFi and enable One WiFi Name to use the mesh feature, and place the extender far enough where it can still get signal from the router and also create coverage in the dead spot.
You can have the Comcast gateway in place and still have another router if you wanted. You would have to put the Comcast gateway into bridge mode which would turn off the routing and wireless. Then you would be able to attach a different router to the Comcast gateway to broadcast the wireless. Of course the other option is if Comcast allowed bring-your-own-modem and still provide DVR service you could replace the whole thing, but it is generally recommended to buy a modem separate from the router not a 2-in-1. This allows you to replace or upgrade each one seprately if needed later. Cheapest solution would be to just add a single extender between the router and dead spot. Check signal strength with a wireless analyzer app to see if you can find good signal about halfway. It depends on the house layout if it will truly work, but would be the least costly way to fail.
- RobS10Mar 10, 2019Aspirant
Apil1,
Thanks again for the info! After already doing some research, I am finally learning something here about how this all functions :-).
Do you have any idea how well the Nighthawk Mesh Extenders like I'm looking at do with lath and plaster walls? The only place I can locate the extender that's mid point to the dead zone is in our breakfast room, but there are still some walls to get to the back bedrooms, than add the foor if we want the downstairs room. I guess another option would be the Comcast xFi Pod Mesh Extenders for about the same price. I'm sure they would work well with the Comcast Gateway, but not sure how well the little puchs would be with walls either. The Nighthawk looks like it has a lot more power, but maybe scattering the three pucks in the breakfast room and back bedroom and garage makes the power unnecessary?
- apil1Mar 11, 2019Apprentice
With any setup it comes down to interference, what else is in the area broadcasting in the same channels and what is physically in between that will weaken the signal. If each one can get a signal strong enough to send to the next one, but that would be for any system you put in place. Describing the physical attributes can't guarantee one way or the other whether extenders will fill in dead spots or not, theres a lot of variables and sometimes you just have to try it and adjust to get the optimal setup.
The Comcast extenders are the same price for the set as one Nighthawk extender you are looking at? It may be worth a try to see if they can be spread out to reach more nooks than a single Nighthawk extender. A single Nighthawk extender may be able to be placed to reach all nexessary areas, but if not you would have to set up more to get everywhere.
