Barney009
Mar 03, 2024Aspirant
Nighthawk AC1900 extender
Hi I have the subject extender and all four lights are green, but I the nighthawk link does not come up to connect to. What am I doing wrong? thanks
Mar 04, 2024Guru - Experienced User
things you're doing wrong?
1. AC1900 is a speed, not a model. What actual model do you have?
2. Most of the AC1900 classes of extenders are Mesh extenders. Meaning they'll have the same exact ssid/password as the primary router unless you disable it. So if you set it up using the WPS process or the assistant, its default configuration is mesh.
3. if the led for router and the one for devices are both green, its indicating its setup.
Barney009
Mar 04, 2024Aspirant
Hi, thanks for the response
I have the Wifi Mesh Extender Essential Edition.
All lights are green on the front of the unit, I even have a network cable plugged in but when i go to set up the extender in the Nighthawk app (attached screen shot) the network name "Netgear_EXT" does not show at all, so cannot set the unit up to be abe to connect to it.
Any further thoughts or suggestions?
appreicaye the help
Drew
