gerz
Mar 13, 2018Aspirant
Nighthawk AC1900 Model EX7000 SN 46D57C7FA2717
Just bought this extender. Needed it because couldn't get automated blinds to access internet. Still blinds not installed; will be installed end of month. 2 questions: How do I know this exten...
jvasanth1984
Mar 15, 2018Virtuoso
Hi gerz,
Did you tried setting it up using WPS or browser method? For antenna, ensure it was screwed in properly but not too hard since it might damage the threads to which you are screwing it to the device.
gerz
Mar 15, 2018Aspirant
I used the browser method.
Re the antennae, yes I screwed them in securely but not over tight.
It's the part of each antenna which you can move around that falls down.
- jvasanth1984Mar 15, 2018Virtuoso
Hi gerz,
Scan and connect your devices to _2GEXT or _5GEXT network which is your extender's network to see if it works. Also, ensure 2.4 and 5GHz LEDs on extender is Green which will indicates that extender is connected to your router. For antennas, see if you can make them stay in a position.
- gerzMar 16, 2018Aspirant
I don't see where the light is! I've looked on all sides and I don't see a light and I don't see where the light should be.
As for the antennae, I'm trying to keep the antennae in place, but with the slightest movement around them, they fall down.
- jvasanth1984Mar 16, 2018Virtuoso
Hi gerz,
I have attached a picture indicating where lights must be. To know more about LED status, you can check the user manual http://www.downloads.netgear.com/files/GDC/EX7000/EX7000_UM_21dec2014.pdf in page 7 and 8.
