ECups's avatar
ECups
Nighthawk AC1900 or Nighthawk A6S - Which is best
I have Spectrum internet and would like to extend my network into my basement.  Also get full capability and single network name/option.  Right now my extender is only picking up the 2G and not the 5...
  • plemans's avatar
    Feb 17, 2020
    The EX8000 is going to have more performance because of its tri-band capability. it reserves 1 of the 5ghz bands just for communication with the router. This reduces latency and increases bandwidth.
    the EX7000 is a dual band extender. You can offset a little of its latency increase by using its own fastlane setup but then you lose out on a band.
    If it was me? I'd probably bo with the tri-band for an extender.
