Flamingplatupus
Jan 31, 2023Tutor
Nighthawk AC1900 Wifi Extender not connecting to WiFi
I just moved into a new location where my room is a bit away from the WiFi Router. I am using the Nighthawk AC1900 Wifi Extender that my friend no longer needed. It was working fine for the last few ...
- Feb 09, 2023
Good luck! I hope it work.
You might check to see if that router supports self organizing network. (son) in its settings.
the older G3100 had to have that disabled or it'd only connect to its supported extenders for a mesh.
Jan 31, 2023Guru - Experienced User
What firmware is on it?
Did you try factory resetting before you started using the installation assistant?
- FlamingplatupusFeb 03, 2023Tutor
I just tried connecting and I run into the same issue. It says searching for WiFi networks and backs out of the page.
The firmware version is listed as follows:
- Hardware Version: EX7000
- Firmware Version: V1.0.0.30_1.0.72
- plemansFeb 09, 2023Guru - Experienced User
A couple things.
1. What router are you connecting it to?
2. You're on really really old firmware. Its the initial release firmware. Try upgrading it to the 1.0.1.112 firmware and installing it.
https://www.netgear.com/support/product/ex7000#download
- FlamingplatupusFeb 09, 2023Tutor
Alright, ill attempt to update the firmware as soon as I return home. I am connecting to a Verizon CR1000a Router.
Thanks again for your continued support!
