Flamingplatupus
Jan 31, 2023Tutor
Nighthawk AC1900 Wifi Extender not connecting to WiFi
I just moved into a new location where my room is a bit away from the WiFi Router. I am using the Nighthawk AC1900 Wifi Extender that my friend no longer needed. It was working fine for the last few ...
- Feb 09, 2023
Good luck! I hope it work.
You might check to see if that router supports self organizing network. (son) in its settings.
the older G3100 had to have that disabled or it'd only connect to its supported extenders for a mesh.
Feb 09, 2023Guru - Experienced User
Flamingplatupus
Feb 11, 2023Tutor
Worked perfectly. Thank you so much for your time and help!
- plemansFeb 11, 2023Guru - Experienced User
Glad it worked!
