RegaPlanar
May 16, 2020Aspirant
Nighthawk AC2200 Ex7300 v2 New - power LED blinking - will not factory reset and cant connect to it
Hi I have a brand new out of the box Nighthawk AC2200 Ex7300 v2 and when I power it up I cannot get any further than a blinkngi green power LED light. Will not factory reset. Not visible on network...
- May 17, 2020
plemans, you are a great big legend, Guru doesn't even cover it.
Installed the firmware via tftp and now have full bars in the hammock.
Thank you kindly.
Regaplanar
May 17, 2020Guru - Experienced User
You can try recovering it via tftp
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
- RegaPlanarMay 17, 2020Aspirant
Thank you kindly.
Regaplanar
