Riddler0712's avatar
Dec 03, 2021
Nighthawk AC2200 x6
All, I am new to this, but have set up my extender as an access point, plugged directly into Cat6 Ethernet running at 350gbps fibre, yet the max WiFi speed obtained from the access point on 5ghz channel is a disappointing 86gbps.
isnthere anything in the settings that would help dial this up, or do I accept that this hardware is not designed as an AP and will never pull the full fibre speed?
basically what I am asking is should I buy a dedicated AP, instead of pretending my extender it is an AP, or can I tweak what I have for more speed.
  • plemans's avatar
    Are you using smart connect on the EX7700?
    If so, it'll steer devices between the 2.4ghz, and the 2x 5ghz channels.
    If you're device is on 2.4ghz, thats about what you can expect for speeds because 2.4ghz is a slow network.
    But the 5ghz should be faster.
    So what band are you connected to when you're speedtesting?
    • Riddler0712's avatar
      Riddler0712
      Tutor
      Hi there Thankyou for the response. No I switched off the smart setup and went straight for the 5ghz option. So the device is only connected to that one, nothing else.
      • plemans's avatar
        What speeds are you getting over each of the following?
        1. wired into the EX7700?
        2. 2.4ghz on the ex7700?
        3. 5ghz-1 on the ex7700?
        4. 5ghz-2 on the ex7700?
        how are you testing speeds? (device, app, browser, ect)
        have you tried other devices?
