Riddler0712
Dec 03, 2021Tutor
Nighthawk AC2200 x6
All, I am new to this, but have set up my extender as an access point, plugged directly into Cat6 Ethernet running at 350gbps fibre, yet the max WiFi speed obtained from the access point on 5ghz chan...
Riddler0712
Dec 05, 2021Tutor
I use Speedtest by ookla for consistency across all devices and locations.
I have not tried a wired connection into the 7700, only wireless on my iPad.
2.4ghz around 12 to 16 mbps
5ghz 1 around 88 to 92 mbps, and same for connection 2
downstairs on wireless from same iPad, and ookla, I am pulling 350 to 360 mbps
Dec 05, 2021Guru - Experienced User
I have not tried a wired connection into the 7700, only wireless on my iPad.-----Try a wired connection. I'm suspecting the extender is only connecting at fast ethernet speeds (10/100mbps) and not the gigabit its capable of. If wired is only 92-96mbps, try replacing the cable between the extender and the router. Or if its a in-wall cable, move the extender next to the router and use a known good 6ft cat 5E or great cable to test it with.
2.4ghz around 12 to 16 mbps---2.4ghz is a slow network. You might be able to improve this with switching channels on it.
5ghz 1 around 88 to 92 mbps, and same for connection 2----again, suspecting that its limited by what its connecting to the router at. If its only connect at faster ethernet speeds, then I'd be suspecting the cable.
Test its wired speeds.
Then if its still hitting only that 100mbps ish speed, move the extender to right by the router and use a known good cable. I've seen to many sketchy cat 5e cables that don't connect at gigabit speeds.
