Jfosterjrod58
Dec 27, 2018Aspirant
Nighthawk ad7200, X6S mesh extender, specs for ethernet ports please
I am about to network my new Nighthawk ad7200 router and X6S mesh extender. They will have considerable obstacles in between them that may cause interference in the wifi signal. I am considering to ha...
- Dec 27, 2018
The 7700 is set for the following:
Maximum Wireless Speed: 2200 Mbps (1733ac+450n) WiFi standards supported: 802.11a (54 Mbps)
802.11b (11 Mbps)
802.11g (54 Mbps)
802.11n
802.11acAC2200† WiFi - Band 1: 400Mbps @2.4GHz - 256QAM - Band 2: 866Mbps 5Ghz - 256QAM - Band 3: 866Mbps 5Ghz - 256QAM • IEEE® 802.11 b/g/n 2.4GHz • IEEE 802.11 a/n/ac 5GHz • IEEE 802.11 k • Two (2) 10/100/1000 Ethernet ports with autosensing technology
So it doesn't support AD modes like the AD7200 does
Maximum Wireless Speed: 7200 Mbps (4600ad+1733ac+800n) WiFi standards supported: 802.11a (54 Mbps)
802.11b (11 Mbps)
802.11g (54 Mbps)
802.11n
802.11ac
802.11ad• AD7200† WiFi - Band 1: 800 Mbps @2.4GHz – 256QAM - Band 2: 1733 Mbps @5GHz – 256QAM - Band 3: 4600 Mbps @60GHz – SC • Powerful Quad-Core 1.7GHz processor • Memory: 512MB NAND flash and 1GB DDR3 SDRAM • Enhanced Active Antennas with high powered amplifiers • Explicit Beamforming for 2.4 & 5GHz bands • Seven (7) 10/100/1000 Mbps Gigabit Ethernet ports - 1 WAN & 6 LAN - Dual Gigabit Ethernet Port Aggregation
Ethernet ports are CAT5/6 rated. All ports are up to 1000Mb speed rated. I presume CAT7 since thats just an update to CAT6. CAT6A is inwall cable cabing and Not a inter connect cabling between devices. I have CAT6a in my walls and use CAT6 patch cabling from the walls to devices and switches. You don't necessarily have to use CAT7. CAT6 has been working great for me over the years. ZERO issues.I've used the EX7700 has an extender and wired AP. Work well with my XR450/R7800 routers.
I've tested my EX7700 at a 40 feet range inbetween with the EX at one end of the house and the main host router at the opposite end. Good range and coverage and performance for my home. Of course this is all based on building materials and having concrete walls and such will impact signal and coverage since 5Ghz is effected by buiding materials due to it's high frequency and nature. Wood and dry wall not so much.
What is the Mfr and model of the ISP modem?
Dec 27, 2018Guru - Experienced User
| Maximum Wireless Speed: | 2200 Mbps (1733ac+450n) |
| WiFi standards supported: | 802.11a (54 Mbps) 802.11b (11 Mbps) 802.11g (54 Mbps) 802.11n 802.11ac |
| Maximum Wireless Speed: | 7200 Mbps (4600ad+1733ac+800n) |
| WiFi standards supported: | 802.11a (54 Mbps) 802.11b (11 Mbps) 802.11g (54 Mbps) 802.11n 802.11ac 802.11ad |
Jfosterjrod58
Dec 29, 2018Aspirant
Hello FURRYe38,
Thanks for all the good info. My modem is an Arris TG1682G. My ISP is Spectrum... 😒.
We pay for their "Lightning" speed internet, but I'm not sure what the max Mbps is for that.
It has 2.4 and 5 Ghz wifi, but it doesn't tell me which of the 802.11 speeds it is compatible with. I do intend to purchase my own if Spectrum is charging me extra for the rental. Recommendations would.be appreciated.
- StephenBDec 31, 2018Guru - Experienced User
It has 2.4 and 5 Ghz wifi, but it doesn't tell me which of the 802.11 speeds it is compatible with. I do intend to purchase my own if Spectrum is charging me extra for the rental. Recommendations would.be appreciated.The Arris looks like a 3x3 802.11ac system, so it should be an AC1700 router. Though I don't understand why you'd care about its wifi speeds if you already have the Nighthawk X10 router.
- Jfosterjrod58Dec 31, 2018Aspirant2 reasons...
1.) Possibly eliminating any rental charges
2.) That is the isp modem, whereas the Nighthawk will be my vpn. Rental modem may be a bit of a bottleneck to the outside world.- StephenBDec 31, 2018Guru - Experienced User
1.) Possibly eliminating any rental chargesOf course you need to decide if you want to purchase a modem or not. But it seemed to me that you wouldn't be using the wifi in the Arris, so it's wifi speed wouldn't matter. Your ISP speed would matter, and of course you want a docsis modem that can keep up with your ISP.
2.) That is the isp modem, whereas the Nighthawk will be my vpn. Rental modem may be a bit of a bottleneck to the outside world.Are you saying that you will continue to use the Arris directly when accessing the internet (using the Nighthawk only when you are using the VPN service)? Or will all your internet access be done through the VPN service?
Whether the Arris is a bottleneck depends on your ISP upload/download speed. What are those speed?
