mscarolt
Aug 31, 2021Guide
Nighthawk and cable TV
I recently installed a Nighthawk Mesh WiFi 6 System. It has improved WiFi throughtout our home, however, the remote for our Spectrum cable box barely works. It is sluggish if it works at all. This s...
- Sep 01, 2021
Thank you. I will try this today. Very helpful.
Aug 31, 2021Guru - Experienced User
A model number for both would help. Spectrum has a lot of models. And even models that look the same but have different internals.
If its potentially an issue with the wifi interfering, you should be able to change what channel the router uses. Try changing what channel the 2.4ghz is on.
