davet59
Jun 19, 2020Tutor
Nighthawk app is requesting admin PW for my AC3000 Extender
When trying to acces my AC3000 Range Extender on the the NightHawk app it is asking me for the admin password. It is not the default and I have tried every known password that I normally use. How do ...
Maratmk
Jun 22, 2020Tutor
I have similar issue. When trying to connect to extender using Nighthawk android app getting the error: "Login failed. Please re-enter the correct password ...". I am entering the correct password since the same login credentials work when connecting using Web interface.
It must be something with Nighthawk app or the way it talks to the device.
Note: I setup the device using WPS, not NIghthawk app if this matters.
olympos1625
Jun 25, 2020NETGEAR Employee Retired
Hi davet59 and Maratmk,
Good day!
Welcome to NETGEAR Community!
Thank you for reaching us out. Have you tried logging in using the web browser and see if it has the same issue? If not yet, please do so so we can isolate the problem if it's on the app only or both.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
- davet59Jun 25, 2020TutorYes it works just fine from a web page.. I have tried several factory reset and cannot log on from the app. It give me the invalid password error
- MaratmkJun 26, 2020Tutor
Same in my case. As I mentioned in the original post I can connect to the extender using Web browser with the same cresentials as I use in Nighthawk android app.
- olympos1625Jun 26, 2020NETGEAR Employee Retired
We would need the following information, so I can offer you additional recommendations:
1. What device are you using in accessing the NH? Android or iOs?
2. What is the version of the Android or iOs?
3. Have you tried using a different device?
4. What is the current firmware version of the extender? What is the app version of the Nighthawk app?
Oliver
Community Team
