David9
May 17, 2022Aspirant
Nighthawk app no longer works with my EX7700 X6 wifi extender
Every so often the EX7700 X6 wifi extender just seems to slow down and sometimes I find the Nighthawk App on my iphone no longer works. Recently I factory reset and tried several times to get the app...
May 17, 2022Guru - Experienced User
Be sure to disable WiFi Private IP address and IP Address Tracking for the wifi network your connecting too. See if this helps.
- David9May 17, 2022Aspirant
ty but it was working and nothing else has changed on my wifi network.
- plemansMay 18, 2022Guru - Experienced User
What router are you connecting it to?
did you set it up using wps or the installation assistant?
- David9May 18, 2022Aspirantty I did a factory reset and then used the setup by: 1. connecting to the local extender wifi 2. using the browser to configure the unit.
