David9
May 17, 2022Aspirant
Nighthawk app no longer works with my EX7700 X6 wifi extender
Every so often the EX7700 X6 wifi extender just seems to slow down and sometimes I find the Nighthawk App on my iphone no longer works. Recently I factory reset and tried several times to get the app...
olympos1625
Jun 07, 2022NETGEAR Employee Retired
Hi @David9 and reubster,
Thank you f reaching out. We are sorry for not being able to get back to you immediately. May we know when exactly did you notice the issue on your extenders? Also, did you do a firmware update recently? If yes, have you tried using a different firmware version?
https://kb.netgear.com/000061572/How-do-I-manually-update-the-firmware-on-my-NETGEAR-WiFi-Extender
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
reubster
Jun 09, 2022Aspirant
> After changing from my ISP and putting in a new router. I solved the problem with connectivity for myself recently - I found that my router was assigning the extender an ip of 192.168.1.250. When I removed the assignment and set it to use .254 then it's worked fine.
I still can't get the Nighthawk app to work though. I've deleted it completely and reinstalled.. it still won't find my extender. I get stuck in a loop where it wants me to reset the extender.. so it can join the temporary wifi.
The web app works fine.
> I don't know. It's the app not the extender.
- olympos1625Jun 11, 2022NETGEAR Employee Retired
Our support team is looking into this issue and would like to work with you
I would like to endorse you to NETGEAR Level 2 support team for a callback. Please provide the following information:
Name:
Email:
Phone:
Preferred schedule (at least 2 days ahead)
Timezone:
Device S/N:
Alternatively, if you wish to be contacted via email only then kindly include your preferred email address.
I am looking forward to your response.
Oliver
Community Team
- David9Jun 11, 2022Aspirant
Oliver, I'd rather not post my personal details here. Can you provide an email address that I can use?
- plemansJun 17, 2022Guru - Experienced User
David9 Send it to olympos1625 in a private message/direct message. Click on their profile and from there click on "send this user a private message"
