David9
May 17, 2022Aspirant
Nighthawk app no longer works with my EX7700 X6 wifi extender
Every so often the EX7700 X6 wifi extender just seems to slow down and sometimes I find the Nighthawk App on my iphone no longer works. Recently I factory reset and tried several times to get the app...
reubster
Jun 09, 2022Aspirant
May we know when exactly did you notice the issue on your extenders?
> After changing from my ISP and putting in a new router. I solved the problem with connectivity for myself recently - I found that my router was assigning the extender an ip of 192.168.1.250. When I removed the assignment and set it to use .254 then it's worked fine.
I still can't get the Nighthawk app to work though. I've deleted it completely and reinstalled.. it still won't find my extender. I get stuck in a loop where it wants me to reset the extender.. so it can join the temporary wifi.
The web app works fine.
Also, did you do a firmware update recently? If yes, have you tried using a different firmware version?
> I don't know. It's the app not the extender.
olympos1625
Jun 11, 2022NETGEAR Employee Retired
Hi @David9 and reubster,
Our support team is looking into this issue and would like to work with you
I would like to endorse you to NETGEAR Level 2 support team for a callback. Please provide the following information:
Name:
Email:
Phone:
Preferred schedule (at least 2 days ahead)
Timezone:
Device S/N:
Alternatively, if you wish to be contacted via email only then kindly include your preferred email address.
I am looking forward to your response.
Oliver
Community Team
