tperrine's avatar
tperrine
Follower
Jun 30, 2021
Nighthawk app won't recognize extender
My extender is plugged in with green light showing that my phone is set to the wifi connection of NETGEAR_EXT, but when I try to have the nighthawk app find the extender, I get the message that the extender can't be found. It says I am connected to NETGEAR_EXT. Go to WiFi and connect to NETGEAR_EXT. I 've tried factory reset, uninstalling the app, two different routers. This should have been an easy fix, but nothing is working. Can someone help me, please?
1 Reply
  • plemans's avatar
    have you tried installing it using the browser and not the app?
