Ruairic
Mar 24, 2020Tutor
Nighthawk app
So I’ve recently got the EX8000 to boost my WiFi in my room but when I use the app it says my firmware needs and update and to go to the website where I can update it. I can view my extender there but...
- Mar 25, 2020
glad to hear you got it up and running properly!
Mar 25, 2020Guru - Experienced User
So try the manual update.
here's the support site.
https://www.netgear.com/support/product/EX8000
click on downloads and download the most recent firmware and extract how I listed prior.
Page 43 of the manual walks you through manually updating the firmware. Try this method.
Ruairic
Mar 25, 2020Tutor
Ok sorry for leaving you hanging. I was doing what you said but it took longer then I thought but it did in fact work. Thanks so much for taking the time to help me with this. Hope you and yours are ok during these trying times ! 🤙
- plemansMar 25, 2020Guru - Experienced User
