rnnighthawk
Nov 06, 2020Follower
Nighthawk AX5200 RAX48
Hello,
I just bought the Nighthawk AX5200 from BestBuy but after setting it up, i'm still having troubles with streaming HBO Max/YoutubeTV.
I stream HBO MAX from my laptop to TV and it still buffers every second even though the router is right outside my room less than 5ft.
Am i setting something up wrong? There is only 2 device connected to the nighthawk, my phone and laptop. The other devices are still connected to the ISP router.
1 Reply
so you have and isp router and then the netgear connected to it?
Are both running in router mode?
It'd be called a double nat
