TulipTowers
Aug 27, 2020Aspirant
Nighthawk AX8 8-Stream AX6000 WiFi 6 Mesh Extender(EAX80)
We've just purchased Nighthawk AX8 8-Stream AX6000 WiFi 6 Mesh Extender(EAX80) as we have a lot of smart tec running in our home and our wifi was struggling. We are setting it up and just wondered if...
TulipTowers
Aug 28, 2020Aspirant
Thanks for your reply.
I've rebooted but if anything the Nighthawk AX8 8-Stream AX6000 WiFi 6 Mesh Extender(EAX80) is making connection worse :(
I'm at a loss as to what to do now....
Aug 28, 2020Guru - Experienced User
What router is it connected to?
Are you connecting to the 2.4ghz band or 5ghz? 2.4ghz is going to be slower and suffer from more interference.
Have you tried moving the extender around? Many times moving closer or laterally can help as it removes obrstructions (like hvac in the walls, etc)
