sugaronline
Apr 28, 2022Tutor
Nighthawk AX8 AX6000 can not connect to internet for 2.4 GHZ channel
I purchased the Nighthawk AX8 at 15 Dec 2021, recently this router can not connect to internet by 2.4 GHZ channel. As I make the different name for 2.4 and 5 GHZ channel. The 5GHZ channel works ...
Apr 28, 2022Guru - Experienced User
1. what firmware is on it?
2. what method of setup did you use? wps, setup with the app, setup with the installation assistant?
3. what router did you connect it to?
sugaronline
Apr 28, 2022Tutor
sorry. got the firmware
Hardware Version: EAX80
Firmware Version: V1.0.1.70_1.0.2
