ernsol
Jan 28, 2023Initiate
Nighthawk AX8 (AX6000) Extender Power Cord
My dog chewed up my Nighthawk AX8 Extender (AX6000) power cord. Where I I get a replacement? Or if 3rd party, what specs do I need to look for? Any help is appreciated.
- Jan 29, 2023
I'm betting if you look on the label for the extender it says EAX80
If so, it should be the matching to what I listed.
Jan 29, 2023Guru - Experienced User
If you're talking the EAX80, it uses part number 332-11494-01
Model number ad2150f10
it outputs 12v at 3.5amps.
this is off my EAX80's info.
ernsol
Jan 29, 2023Initiate
Hi plemans! I really appreciate your quick response. The nameplate on my Extender does not have a "R" only AX8 and below it has AX6000. I do know from the product literature on the Netgear website that it is a 12V, but no other specification is shown. I am guessing the power cord you mention would probably work. Once again, thank you for your help.
ernsol
