mitty1974
Oct 12, 2020Aspirant
Nighthawk AX8 Mesh Extender Max Download Speed
I recently bought a Nighthawk AX8 Mesh Extender to supplement my existing Nighthawk RAX80 Router. With the RAX80 router or even with a device connected to the router via WiFi, I can achieve download ...
mitty1974
The extender model is EAX80 (AX6000 Nighthawk Mesh Extender).
I'm able to get 940Mbps wireless to the router, but only up to ~250Mbps wired or wireless to the extender
Oct 12, 2020Guru - Experienced User
You should be able to check the connection back to the router via the status page.
What's it show for link speed back to router? (also, link speed isn't throughput speed, just using it to check)
What device are you testing on?
Again, keep in mind the speed drop you'll get.
have you tried on multiple devices?
