insomniak
Jun 08, 2018Guide
Nighthawk D7000 - DHCP Address Reservation not Working
I've recently purchased the XR500 + EX8000 combo to replace my Orbi. With the Orbi, i was able to use the DHCP to reserve IP addresses to specific devices via MAC Address IP Reservation. However, wit...
DexterJB
Jun 11, 2018NETGEAR Moderator
Hi insomniak,
Welcome to the community!
The links below may help out in setting up the virtual MAC of the devices that you are looking to connect.
Dexter
Community Team
- insomniakJun 12, 2018Guide
Hi Dexter,
Thanks for the links below and also i'm not sure why the title is for the D7000 and what i have is the EX8000. Thank you for your suggestion below but that doesn't necessarily help with my issue. I don't use MAC filtering but even if i do, I wouldn't be able to assign a static IP to a device that has multiple MAC Addresses with Virtual MAC Addresses since the router i have (XR500) only allows an IP address to be assigned to a single MAC Address. In the suggestion below, a device would have multiple MAC Addresses even if MAC Filtering was enabled.
To further explain, i don't have issues with devices that are hardwired directly into the router as I'm able to assign a static IP through the router as there is no virtual MAC Address. Issue only occurs when i have computers or cameras that are connected through the extender. This is when the Virtual MAC Address is assigned and if they move back and forth between the wireless bands and obtains different MAC Addresses, then my IP reservation for the MAC Address is lost.
