Sandshark's avatar
Sandshark
Sensei
Jul 31, 2021
Nighthawk EAX20 Extender set up -- but doesn't recognize it is
I got tired of a dead spot in my home addition and added an EAX20 extender to fix that.  Setting it up via the app worked as expected, until the last step.  In fact, it clearly is set up, but the app doesn't recognize that it is.
I skipped setting up a 2.4GHz network.  If that's the issue, the Netgear has a big bug to fix.
After I set up the 5GHz network, it went to change my network from NETGEAR_EXT to my network, which it accomplished (verified in my phone's WiFi settings, by 100% signal strength were it would otherwise be <10%, valid Internet access, and all LEDs white except 2.4GHz).  But it just kept trying to verify the connection (to the 5GHz SSID).  So I exited the app and entered it again.  It then said my extender wasn't set up and wants to try again.  No option to go to the dashboard.  It goes through the steps of where to place it, plug it in, etc. then it wants to connect to "your extender's wifi network" (which it only specifies is NETGEAR_EXT after it fails to connect), but NETGEAR_EXT is not even listed when I'm right next to the extender (presumably because it is set up and leaving it open would allow free access to the dashboard).
So, how do i get past this to get to the dashboard and make sure the firmware is the latest, etc?
I'm running the app on a Google Pixel 4a with Android 11, if that matters.
  • plemans's avatar
    Is there a reason you're skipping setting up the 2.4ghz?
    Have you tried using a pc/laptop for setup?  (I'm not a fan of the app setup process)
    • Sandshark's avatar
      Sandshark
      Sensei
      I am skipping the 2.4 GHz because it's got my security cameras on it and I don't need anything else on it when 5GHz is mostly unused and everything that needs WiFi in the area the extender will service is 5GHz capable.  The unit came with no instructions for setting it up via anything other than the app.
      • plemans's avatar
        Sandshark wrote:
        I am skipping the 2.4 GHz because it's got my security cameras on it and I don't need anything else on i-----Never know if it'll help or not. If you set it up with the mesh options (onessid) your security cameras might stay connected to the router or the extender depending on their roaming protocol. I've been pleasantly surprised when my 2.4ghz worked better with an extender running.  It when 5GHz is mostly unused and everything that needs WiFi in the area the extender will service is 5GHz capable. If you've got the capability, spreading devices around (even security cameras) has usually been beneficial to my network.  The unit came with no instructions for setting it up via anything other than the app.----I wish Netgear did a better job of showing the other installation methods. It seems like everytime the app gets updated to fix an issue, it breaks something else. That's why I prefer using the installation assistant. The other half the time, people use WPS and you see ISP supplied devices not coded properly so the extenders not functioning properly.
        here's a video on using the assistant.
        https://www.youtube.com/watch?v=yJVklshxBMk
        And the support site with the manual that goes over it.
        https://www.netgear.com/support/product/eax20.aspx
        Let me know how the EAX20 works for you. I've got the EX8000 and love the dedicated backhaul. I haven't used any of the EAX line of extenders to see how they compare to the tribands.
