glinda3175
Mar 07, 2023Aspirant
Nighthawk eax20 shuts off Wi-Fi to house when connected to ethernet cable
Newbie here - I’m trying to set up Wi-Fi in a separate building from my house, and have run an Ethernet cable from my router to the building. When I plug the eax20 in, it works OK (the signal goes up...
Mar 08, 2023Guru - Experienced User
Did you setup the EAX20 in access point mode?
- glinda3175Mar 08, 2023AspirantAt first I set it up as an extender, and the WiFi in the house shut off. I then set it up as an access point and the WiFi shut off again.when I unplugged the eax20 it came back on.
- plemansMar 08, 2023Guru - Experienced User
The extender shouldn't be impacting the router at all when setup in access point mode or messing with the primary routers wifi at all.
What router is it connected to?
What method of setup are you using? (the app, installation assistant, wps)?
- glinda3175Mar 08, 2023AspirantThe router is a Hitron CODA-5712 that was installed by my internet provider. And I used the Nighthawk Smart set up when I chose to use the extender as an access point (I logged into the Net Gear eax20 to do the set up).
