sysfromhell
May 30, 2022Tutor
Nighthawk EAX80 (AX6000) Telnet
Hey there, is there any way to enable Telnet or SSH on the WiFi Extender/Access Point?
I have multiple problems always with this Extender/Access Point which can only be fixed when I reboot the device.
I want to use Telnet to maybe locate and software fix the problem instead of rebooting randomly all the time.
Kind regards,
Not currently. telnet has be pulled from more devices lately.
1. what firmware version are you on?
2. what router did you connect it to?
3. what method of setup did you use? WPS? or the installation assistant?
1. what firmware version are you on? V1.0.1.70_1.0.2
2. what router did you connect it to? pfSense Router (CE v2.6.0)
3. what method of setup did you use? WPS? or the installation assistant? Installation assistent, normal WiFi Connection (WPA2 Password)
The problem isnt that simple, sometimes the devices says connected but can´t reach the internet.
Some traffic gets lost and can only be fixed via reboot.
have you set a static ip address for it in your pfsense device?
