bargemans
Apr 08, 2021Follower
Nighthawk EX7500
Hi Im trying to connect the extender to my BT hub It connects through 2.4Ghz but not through 5Ghz The BT hub only offers channels 36, 40, 44 & 48 at 5GHz How do I force the extender to connect t...
Apr 08, 2021Guru - Experienced User
Which bt hub do you have?
Are you installing using the installation assistant or using WPS?
i'd try factory resetting (push and hold reset for 7-15 seconds while its powered on) and then install using the installation assistant.
That allows you to select the network when setting up 5ghz.
