Colinclement
Jan 10, 2023Tutor
Nighthawk EX7700 loosing settings
Hi my Nighthawk EX7700 looses its settings if my router drops like if I reboot it. I then have to reset the unit and set up again. Is this a known fault. Thank you. Colin. Uk
Colinclement
Jan 27, 2023Tutor
Hi Oliver I have just purchased another Ex7700 and it works fine. It remembers the settings when I power it off and back on again. It has the same firmware as the faulty one that looses its settings when I power it off and back on again. Is there an address I can send the faulty one to for you to debug ? And finally fix this well reported issue.
Thank you
[email protected]
Thank you
[email protected]
olympos1625
Jan 27, 2023NETGEAR Employee Retired
Hi Colinclement,
Thank you for the information. Please contact our Support team over the phone( 0344 875 4000) so they can do a hardware check. If the issue is hardware and if your extender is still on hardware warranty, we will proceed with the replacement.
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
