sdenyer
Nov 29, 2025Tutor
Nighthawk EX7700 not connecting
Hi I have a Nighthawk X6 AC2200 wifi extender - Model EX7700. It used to work in the past. We had it positioned one floor above the router, and it successfully extended the signal to the top floor...
- Nov 29, 2025
Your extender has successfully connected to your existing WiFi network.
Connect any WiFi enabled device like you would connect them to your main network, using the credentials below.
sdenyer
Nov 29, 2025Tutor
