leedelph
Aug 14, 2024Follower
Nighthawk ex7700 range extender, I'm using it with Amazon Eero router
Hi, I'm using a Nighthawk ex7700 range extender, with Amazon router witch has a fixed 5g channel which is 160. The extender only lets me choose channels from 100DFS to 128DFS. can anyone tell me ho...
- Aug 15, 2024
the EX7700 is a triband extender. It has 2x 5ghz bands. This means that one is a high band and one a low band. So if you're router is broadcasting on the 160 channel, thats what the extender uses for the backhaul (router--extender connection) and uses the lower bands for the fronthaul (extender---device) connection.
Aug 15, 2024Guru - Experienced User
