Dustin_V
Mar 08, 2019NETGEAR Employee Retired
Nighthawk EX7700 WiFi Mesh Extender Wins Prestigious iF DESIGN Award for 2019
NETGEAR is proud to be recognized with a 2019 iF DESIGN AWARD for our Nighthawk EX7700 WiFi Mesh Extender! The Nighthawk X6 Tri-band WiFi Mesh Extender won over the 67-member jury, made up of ...
Donna1408
Apr 10, 2019Aspirant
I am new at this but I do need a wifi extender. Are they compatible with all modems? Also my internet speed is 5k. So I would need on compatible with my speed correct?
- FURRYe38Apr 10, 2019Guru - Experienced User
Extenders are compatible with modems with built in wifi or stand alone routers with WiFI.
What MFr and model# ISP modem/router do you have?
What is your ISP speed UP and down that you pay for. 5k isn't a speed.
- Donna1408Apr 10, 2019Aspirant
I tested the isp speed and it says 67.7 mbps download and 69.7 mbps upload. My modem is from Frontier not sure what you would need from there.
The ex7700 would easily handle those speeds.
What Mfr and model# ISP modem/router do you have?
Are you using a wifi router behind the modem or just the modem router combo?
