Dustin_V
Mar 08, 2019NETGEAR Employee Retired
Nighthawk EX7700 WiFi Mesh Extender Wins Prestigious iF DESIGN Award for 2019
NETGEAR is proud to be recognized with a 2019 iF DESIGN AWARD for our Nighthawk EX7700 WiFi Mesh Extender! The Nighthawk X6 Tri-band WiFi Mesh Extender won over the 67-member jury, made up of ...
Donna1408
Apr 10, 2019Aspirant
I am new at this but I do need a wifi extender. Are they compatible with all modems? Also my internet speed is 5k. So I would need on compatible with my speed correct?
Apr 10, 2019Guru - Experienced User
Extenders are compatible with modems with built in wifi or stand alone routers with WiFI.
What MFr and model# ISP modem/router do you have?
What is your ISP speed UP and down that you pay for. 5k isn't a speed.
- Donna1408Apr 10, 2019Aspirant
I tested the isp speed and it says 67.7 mbps download and 69.7 mbps upload. My modem is from Frontier not sure what you would need from there.
- FURRYe38Apr 10, 2019Guru - Experienced User
The ex7700 would easily handle those speeds.
What Mfr and model# ISP modem/router do you have?
Are you using a wifi router behind the modem or just the modem router combo?
this is a modem model Fios-G1100. says designed by greenwave systems. It's a modem provided by Frontier Communications
