79AG
Aug 25, 2021Aspirant
Nighthawk EX8000 Extender
I changed my EX8000 from an extender to an access point. Now, when I look for 'connected devices' I just get a prompt 'Please wait a moment....' (screenshot attached) that never stops. I don't fu...
Aug 25, 2021Guru - Experienced User
Extender mode is a wireless connection back to the router and it leaves the smart roaming functions enabled.
AP mode is a hardwired connection back to the router. It disables the smart roaming features.
When in AP mode, many device won't roam as well as they used to as the roaming features aren't enabled.
I'd check your wireless channels to make sure in AP mode that they aren't on the same channel as the router. This'll help with interference.
You can also change the name of the SSID so you can manually roam between them.
In terms of the not loading, did you try a different pc and/or browser?
79AG
Aug 26, 2021Aspirant
Yes, I tried using Chrome. Oddly enough, I couldn't even log into the extender. Kept telling me there was a user/password mismatch, which their wasn't. Tried going back to the mesh setup, but the 5GHz network wouldn't connect to my router, so I went back to the access point setup.
