djmercury73
Dec 01, 2022Follower
Nighthawk EX8000 X6S - Which app do I use to install?
I have the Netgear Nighthawk app on ios and while trying to install I get "Extender Not Supported" message. It also says "The Nighthawk app does not support your extender model."
How am I supposed to install if the app doesn't work?
1 Reply
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
