mpb65
Sep 09, 2021Tutor
NIghthawk Extender - Blinking Red Power Light
I unplugged my router as I wanted to change its location. Now when I plug it in the rear power light turns from Green to Red(Blinking) And all the front White lights are blinking. Tried t...
Sep 09, 2021Guru - Experienced User
I notified a moderator to move it. in the meantime,
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
- mpb65Sep 10, 2021Tutor
What Server and Password do I enter into the software?
