quida
Sep 04, 2017Aspirant
nighthawk extender disconnecting
setup extender and it worked great bit every couple of days devices connected to the 2.4 connection are dropped. when I try to connect to it via phone I get message that ip address not found or someth...
DarrenM
Sep 07, 2017Sr. NETGEAR Moderator
Hello quida
Have you updated to the latest firmware? you may also want to assign a static IP in your router to the extender.
DarrenM
- quidaSep 07, 2017Aspirantgreat timing. just got off phone w netgear again. firmware was up to date. they assigned static channel to extender wifi and changes channel for 5ghz. 2.4ghz had channel as auto. will see in a couple of days if it is fixed.
- quidaSep 13, 2017AspirantProblem is back. how do I assign static up address? and if I do this can i change channels on router and / or extender or is it now set permanently?
- DarrenMSep 15, 2017Sr. NETGEAR Moderator
Hello quida
You will have to assign the static Ip in your router and the channel should be the same one your router is using.
DarrenM
