quida
Sep 04, 2017Aspirant
nighthawk extender disconnecting
setup extender and it worked great bit every couple of days devices connected to the 2.4 connection are dropped. when I try to connect to it via phone I get message that ip address not found or someth...
DarrenM
Sep 07, 2017Sr. NETGEAR Moderator
Hello quida
Have you updated to the latest firmware? you may also want to assign a static IP in your router to the extender.
DarrenM
quida
Sep 07, 2017Aspirant
great timing. just got off phone w netgear again. firmware was up to date. they assigned static channel to extender wifi and changes channel for 5ghz. 2.4ghz had channel as auto. will see in a couple of days if it is fixed.
