quida
Sep 04, 2017Aspirant
nighthawk extender disconnecting
setup extender and it worked great bit every couple of days devices connected to the 2.4 connection are dropped. when I try to connect to it via phone I get message that ip address not found or someth...
DarrenM
Sep 07, 2017Sr. NETGEAR Moderator
Hello quida
Have you updated to the latest firmware? you may also want to assign a static IP in your router to the extender.
DarrenM
quida
Sep 13, 2017Aspirant
Problem is back. how do I assign static up address? and if I do this can i change channels on router and / or extender or is it now set permanently?
- DarrenMSep 15, 2017Sr. NETGEAR Moderator
Hello quida
You will have to assign the static Ip in your router and the channel should be the same one your router is using.
DarrenM
