PaoloDaleffe
Aug 15, 2021Aspirant
Nighthawk extender nessuna connessione con iPad e iPhone
Il mio iPhone 12 e l'iPad mi danno l'avviso di 'nessuna connessione' quando mi collego con le reti 2.4G e 5G dell'extender. Il mio PC Windows invece si connette senza problemi. Ho già fatto più vol...
- Sep 28, 2021
Nighthawk extender is now connected with a Technicolor router and it works smoothly.
Don't know why but the probem was surely with Alcatel router.
Many thanks
Aug 15, 2021Guru - Experienced User
when you're installing, do you use the installation assistant or install using the push-button WPS method?
PaoloDaleffe
I tried both ways.
- plemansAug 15, 2021Guru - Experienced User
I haven't seen anyone post about using an extender with that router.
have you tried setting up the extender with a static ip address in the Alcatel HH71
- PaoloDaleffeAug 18, 2021Aspirant
I tried with a static IP addrees in the Alcatel but it doesn't work.
For your information when my iPhone and iPad are in 'no connection' status the following IP address is shown:
IP Address: 169.254.7.52
Subnet mask: 255.255.0.0
Router gateway: none
While the correct IP address from the Alcatel router should be:
IP Address: 192.168.1.10(X)
Subnet mask: 255.255.255.0
Router gateway: 192.168.1.1
- plemansAug 19, 2021Guru - Experienced User
What extender is it and what firmware is on it?
