Hollerway
Aug 31, 2020Follower
Nighthawk extender setup
I'm trying to set up an EAX20 extender via the ap on an iphone 6. The phone can't find the NETGEAR_EXT wifi network. What am I doing wrong?
1 Reply
Did you set it up using wps? If so, the default configuration uses the primary routers ssid as its a mesh extender.
If no, try factory resetting the extender. push and hold reset for 7-15 seconds while powered on.
