Ibaroj
Aug 04, 2023Tutor
Nighthawk guest network disappeared from access points
I have a Nighthawk X6 router with three wired X6S access points. The guest wifi network has disappeared from the access points. It is only visible on the router. Not just a hidden SSID; a wifi analyz...
Aug 04, 2023Guru - Experienced User
Factory reset all EX units and setup from scratch.
Ibaroj
Aug 11, 2023Tutor
I factory reset each EX and the guest network appeared for less than 30 minutes then disappeared again. If I enable the 5GHz guest networks they all work correctly. Looks like a bug. I wonder if they would update firmware anymore.
