g1omaa
Mar 26, 2024Aspirant
Nighthawk M6 Pro heat mitigation
Having troubles with heat warnings on the M6 Pro while using outdoors. The two things I’m considering doing are: removing battery and powering with power bank and/or turning off WiFi on the hotspot a...
g1omaa
Mar 28, 2024Aspirant
g1omaa wrote:Having troubles with heat warnings on the M6 Pro while using outdoors. The two things I’m considering doing are: removing battery and powering with power bank and/or turning off WiFi on the hotspot and running Ethernet to a mobile router with an internal fan https://vlc.onl/.
Anyone have any experience with M6 Pro overheating? What was the solution?
I got this,...
