cgskipper
Jul 28, 2020Follower
Nighthawk Mesh and Armor
I recently purchased the Nighthawk Mesh system when I moved into a larger home. This replaced a Nighthawk X6S AC3600 router. I also use a CM1200 cable modem for Xfinity. If I wanted to keep my Ar...
Jul 28, 2020Guru - Experienced User
yes you can go that route. (modem---->X6S----->mesh in ap mode)
or you can transfer armor over if the mesh you bought has that capabiilty yet.
