RJ-Aus
Sep 03, 2020Follower
Nighthawk Mesh MR-60, firmware update broke Chromecast
I purchased an MR60 Mesh router recently. Setup went smoothly and everything worked fine, until a firmware upgrade to v1.0.4.98. Prior to the upgrade, my Google Chromecast device worked perfectly. Im...
Dckf
Nov 27, 2020Aspirant
Hi
I'm also having the same issue. I performed factory reset on the Chromecast several times and sure enough it didn't work. There's definitely AP isolation even with Upnp turned on.
Need a fix!
Need a fix!
- LexxgearNov 27, 2020Initiate
So, after so many weeks, trying every poissible setting, rebooting multiple times, I finally caved in, and ordered TPLink Deco model from Costco... Guess what? Everything is working normal with all my Google units.
