jpgb
Sep 19, 2019Tutor
Nighthawk Mesh or Orbi
Hello I have a Nighthawk AC1900 Smart WiFi Router(R7000) and the Extender EX7000. I intend to move to a Netgear mesh System. Is there a cost effective way to upgrade my current system to mesh o...
jpgb
Sep 19, 2019Tutor
Thanks
and the option of keeping the Nighthawk AC1900 Smart WiFi Router(R7000) and adding the Netgear Nighthawk X6 EX7700 Mesh Wi-Fi compared to an Orbi System
Sep 19, 2019Guru - Experienced User
If you're only using a single extender, its not a bad option. Again, if you'll only need a single extender, you should be fine. Once you move past a single extender then I'd be looking at a fully mesh setup. I've never had the fortune of using the ex7700 but it seems like a decent extender. I know its around $160 on amazon. If you look on amazon for a renewed (aka refurbished) rbk43 kit, it isn't a whole lot more.
- jpgbSep 19, 2019Tutor
Thanks
