jpgb
Sep 19, 2019Tutor
Nighthawk Mesh or Orbi
Hello I have a Nighthawk AC1900 Smart WiFi Router(R7000) and the Extender EX7000. I intend to move to a Netgear mesh System. Is there a cost effective way to upgrade my current system to mesh o...
Sep 19, 2019Guru - Experienced User
If you're only using a single extender, its not a bad option. Again, if you'll only need a single extender, you should be fine. Once you move past a single extender then I'd be looking at a fully mesh setup. I've never had the fortune of using the ex7700 but it seems like a decent extender. I know its around $160 on amazon. If you look on amazon for a renewed (aka refurbished) rbk43 kit, it isn't a whole lot more.
jpgb
Sep 19, 2019Tutor
Thanks
