JeffreyY
Nov 23, 2020Guide
Nighthawk Mesh WiFi 6 - MK63
I am considering buying the Nighthawk Mesh WiFi 6 - Model MK63. I just moved into a three story house. I currently have a 300mps internet service. I am planning on placing the router on one floor a...
Nov 23, 2020Guru - Experienced User
I'd recommend an old triband (like the rbk43/53) over the MK62.
the tribands have a dedicated backhaul. They tend to have faster speeds/performance. I'd choose that over the MK62.
If you were determined to go AX, I'd look to the triband orbi's.
Or if you had a way to hardwire in the satellites, then it'd be worth the MK62
