deepkd
Aug 24, 2021Aspirant
Nighthawk Mesh WIFI 6 MK62 - can this be used with a TPG modem router -TPLINK AC1600
Can i used this Nighhawk product with a modem router that my provider TPG have give me which is a TP - Link ARCHER VR1600v AC1600? I have been told it should be fine but failure to set it up and spe...
deepkd
Aug 25, 2021Aspirant
Thank you Mate.
My technical knowledge is limited soo I’m going to investigate your options.
I also have the option to return the mesh device and but something else which can resolve the issue and not having the do the things you have suggested. Basically looking for the easiest option that will help drop outs.
deepkd
If i choose to keep this product will the support team help me set it up on my current TPLink? i am not technical so i am finding it hard to work out. BUT I am also very frustrated as my internet is soo poor even though TPG are saying its fine.
Any guidance will be greatly appreciated.
- plemansAug 25, 2021Guru - Experienced User
Even returning it for something else might run into the same issue as you're still cascading routers and causing a double nat.
New devices do come with 90 days of free support. Simply click on "mynetgear" at the top. register an account and the device. From there you should be able to contact support for using the free 90 days.
